I need someone to tell me what this is
talontsiboy24
868
3
Mar 28, 2009
60457, Illinois
Im just wondering what this is where i pointed the red arrow to? it just seems something is wrong with that picture. its a wire attached to something i dunno.
also as u can see my throttle body nipples are all capped off but one and that one is running to my mbc so is that ok?
Just put a spade terminal on the end of the wire and plug it in the way its supposed to be. It comes with a rubber boot from the factory but they deteriorate with time and you end up with what you have now.
As I told you, the pressure line for your MBC should be tapped from an intercooler pipe/compressor housing nipple. You may have to drill and tap to install a nipple in your intercooler pipe if your current ones don't come equipped with a nipple.
A drill and a tap would be necessary. Bit and tap size will depend on how big of a nipple you decide to install. 1/8" to 1/4" NPT work fine. Match the hose barb size to your vacuum line size.
