I need some help with a new engine
tsilover
254
Oct 20, 2002
A rebuilt engine was just put into my car and I am having problems, not with the mechanical components but rather with electrical. The car will not start the first couple of times the key is turned. It will also stall when it is driving and then it will not start for quite a while. I am getting an engine code of CAM and Crank angle sensors. I was going to buy both and replace them since I was going to have the timing belt off and the auto parts place said there were 2 crank angles sensors, I only know of one. Is there one I am not seeing or should I go to another parts place? Thanks.
did you have your engine rebuilt or is it another one? if so what year?
i think the sensor thing is that the 95-96 cars don't have a cas on the head and the 97-99's have it on the intake cam
