I need help with a template (home made wheel spacers)
definitiveno
1,237
8
Sep 8, 2004
Reno/Sacramento, California
Given that my tire just barely, barely, rubs the inner knuckle I was going to have my neighbor hook me up with a couple aluminum sheet metal plates to squeeze behind the rim. The plates will be 1/4 of an inch, is that too much for the stock lug bolts?. I was wondering if there was any way you guys help help me make a computer template to give my neighbor.........
That will be too much for the stock studs i have 5mm spacers are probobly too big just a few threads on the stock stud caught. Home made parts are not very safe to put between your wheels and hubs. You could get a manufactured set of 5mm spacers for $40-$50 that is worth the peice of mind and if your home built ones are not balanced your car will vibrate.
You're going to need longer studs. 8 full turns of thread engagement of the lug nuts is minimum. I believe with stock wheels and studs you get about 10 or 11 full turns. Spacing 1/4 inch will bring you down to about 6.
Why don't you test spacing 1 or 2mm with washers. You may find you need much less than the 6mm (1/4) spacers you proposed. I don't recommend leaving washers on there though.
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
