i need help wiring a prosport o.p. gauge, and a sending unit?????
dberry
32
Apr 9, 2012
Clarksville, Tennessee
I have a premium stepper motor series, oil pressure gauge with sending unit and I need to know how to make it work? There is a white, orange, green, black, and red wire, I got the gauge to power up with the black and red but what wires make the sending unit work and do I need to run a hot wire to the sending unit?
This may be more in-depth:
http://prosportgauges.com/instructions/evogw/EVOgwOPOTWT.pdf
On your oil pressure sending unit:
"G" is the signal output - it runs to the green wire.
"WK" is a ground - try to ground it separately from other grounds.
The orange and white wires can be run together in different combinations to produce different colors on the gauge by hooking them to your accessory power source (or parking lights as needed).
