i need advice
ozeclipse99
Oct 6, 2003
before i put nitrous (70 shot),header 4-2-1,and my msd ignition i ran 10.40's in a 8th mile and the other night i went to the drag strip with al this stuff installed and all i ran was 10.00 .my ? is why didn't i gain more or what can i do to get lower times than what i have. i really appreciate any help you guys can give me thanx :dsm:
i have msd oem replacement coil pack-msd wires-apc intimidator muffler-4-2-1 pacesetter header-ractive cold air intake-nos 70 shot with purge-neuspeed short shifter-dual friction clutch.And yes i did run the spray at 1100 psi i don't know whats up with it i hooked great my highest reaction time was .135 so any advice u can give me i will greatly appreciate. ohh yeah i have denso iridium plugs :cry: :cry:
well change those plugs if your spraying, iridiums = no no w/ nitrous
I cant see why you had such high times, i mean even if you take into account weather its still not ..... umm yea. Reaction times are supposed to me .500 = ideal and .153 = false start no?
Did you miss a shift? I really dont see why your times didnt improve.
i was told by nos and several other tuner shops that its good to have iridium plugs in their because of their ability to still fire under high combustion and keeping u from miss firing while using nos.i hit all my shifts perfectly the only thing i can think of is hack the factory converter and get a ecu upgrade
oooh yeah the drag ways up here consider anything below.000 a false start if u can think of anything or if anybody else thinks of any thing i'm all ears
thanx for the help so far miami if u ever need help let me know
this has been bothering me all day, i have gone to all my classes and i still think...Why is he running such slow times wit all the mods he has put on?
Your stock cat might be failing? Try a hi-flow cat. At night check ure spark plug wires if htey light up like a christmas tree its time to change them. I dont know about that iridium but ive been told good old copper plugs for nitrous. You would notice if ure ecu was failing so i doubt it is that.
Try going to the track again and let us know what u get, PS Where you grabbing any traction?
yeah i was hookin great off the line and my shifts where perfect i jus been real aggrevated with it i was goin to the track tomarrow but its closed due to rain for the weekend
