I keep blowin fuses
Try to unhook your CD player and see if it stops blowing the fuse. I had the same problem from a wire in my CD player that somehow started shorting out on some metal after it had been installed for almost two years.
I had the same problem, it was the green/white wire in the radio wiring harness. It cannot be grounded. If it is, it will cause this problem. I believe it is the illumination wire. Disconnect your deck and see if the fuse blows then you will know if it's the wire. The stock wiring harness has no ground, the stock deck is grounded through the mounting brackets so check and see what was used as a ground.
When your radio wire was shorting your taillights, it wasn't by chance messin with your interior lights also was it?? :talon:
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
