I keep blowing fuses
Batmobile
431
Feb 23, 2004
Olathe, Kansas
Help with Cooling Fan Relay Bypass Mod that is found on VFAQ
this is on the TSi AWD Talon
I did this a couple of months ago.
And now it's getting to the point where it's getting WARMER out side...so I'm starting to use it a little. Well it's blown a couple of fuse's and now has over heated once.
Is there a better way then the way I did it from VFAQ? I had my good friend do the wireing while I did something else..and his a wiz with wires and such. He NEVER did like the way it was wired in to the relays. Just woundering if anyone else has done this and had the same problems or even better now of a better way.
Thanks
check the condition of the wires, shortiges, raw wires exposed, and if they are touching.
