I just recieved a slowboy g-60 trim
Stick to your plan of getting those injectors for the exact reason you said. Also you are going to be pushing the limits of the stock block if you run that much boost with that turbo. I have my boost set at 28psi with my sbr 50 trim. I would keep yours in the 25psi range. You will still have one fast ride if your tune is good and you have the supporting mods.
what kinda of injectors and wastegate are you using??? with ## G50?
At least you are smart and going overkill now incase you ever want to upgrade. Plus with link you should be set to tune.
This is good news. I plan to be running the G60 with the 4" Shroud Compressor on pump gas just over 23psi too. I was worried that it would be a little big, as the compressor housing will be the same size as my buddy's fp3575, but now I'm really excited. Can't wait to make some decent power outta my new block.:thumb: And it's way more affordable than a 3575.
I was looking at this turbo also since you can get it for 650 and 750 with the 4" cover.
