Got a 60 trim but no FMIC just Stock
cmptrphreak
194
Jan 7, 2005
Chicago, Illinois
I recently bought a sbr g-60 with the upgraded 4"compressor housing. Ive got a set of 650 cc rc injectors a 255 lph fuel pump, blowthrough setup with thegm maf and translator. Can I run the car or is it a bad idea to run it since I dont have the fmic? Ive got a logger too so i can seee everything tahts going on. The motor itself is built the bottom end has ross pistons scat rods ...
Whats your wastegate spring psi? you could run 10 psi I would say safley, anymore and you might heat soak. Just watch your logger very closely.
Since you have a logger, its doable. Just watch carefully for knock (pulled ignition timing). With that 60trim it won't take much at all to heat soak the SMIC so I wouldn't run that setup for long. Just hurry up and get a FMIC.
Or you could add water/meth injection to cool down intake temp and almost eliminate knock.
I used to run a big 16g at 22 psi, 560cc inj, and stock ic with w/i.....never got a count of knock and inj duty cycles were below 90%.....this was at the strip with about 15 minutes between runs
Wow, do yourself a favor and get an FMIC. You can get a street kit for 499.00 and get free shipping to boot. Why would you not get one? Don't listen to these other people, take it from someon who has blow motor from being cheap. Do it right once, and you'll never worry about it again.
