I cant Fix my Camber!
Johnny123
95
Aug 12, 2007
Fayetteville, North Carolina
ok so ive had a problem with my camber since i lowered my car about a year ago..and i finally got a camber kit and installed it but now my rear wheels kind of point inward towards the front of the car..like a bulldog...i put the camber kit in correct..what went wrong??
Along with your new camber adjustment, there is another adjustment back there called "toe". Basically, it's the relationship of the direction between one tire to the other. You really need to have your car aligned, if you drive it like that, it will chew the tires up and handle like crap.
Do you mean the front of the tires point inward? If so it is because when camber changes so does the toe.
take it to an alignment shop and have them align it correctly like said above. and when done make sure you get a print out of the alignment. just to make sure everything is in. if not the other guy is right you will go through tires fast.
ok thanks, when i took it to the alignment shop they said they have to make a bigger hole for the arm to adjust with the camber because the adjustible toe wasnt enough.
