Hydro Locked Motor... How To Fix?!?!!?!?
Cxmoney
Jan 12, 2009
Villa Rica, Georgia
so i bought a 1997 5 speed talon the other day and the guy i bought it from said he was ran off the road into a decent sized puddle and the AEM intake sucked in all the water. its a 420A engine from an eclipse. i havent really done anythign with the car cause i have no idea what to do. i was planning on swapping motors, but i was told it can be fixed. can it? the guy said the cylinders had 0 compression(idk if he meant all or just one or two) but the engine does turn over freely, it just doesnt catch fire. what should i do? remove the head? drop the oil pan? or what? Help please. im a beginner mechanic. thanks so much for the replies. (if i get any)
Engine is 99% toast if theres water in it, pull all the plugs and drain the oil to see if theres any in there.
Don't crank the engine with the plugs in it!
Might even have to take off the intake manifold to make sure theres no water hangin around.
well first is first check compression yourself and then if you are getting no fire change your plugs then if not after that pull the head off and see why you arent getting any compression (probably rings then)
but then check for water in the tank just pour some rubbing alcohol in there it will dry up the water if there is any and then change your oil
and if there is any water in the cylinders pull the plugs and crank it over
start with dropping the oil. i work for toyota and about a year ago we had a brand new highlander come in hydrolocked, the tech dropped the oil and the first half came out looking normal, then the last half was all milky looking. he put oil back in it and after a mintute it started again. maybe youll be that lucky
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 2g NEW OEM FWD Fuel Level Sending Unit
    2G NEW OEM FWD Fuel Level Sending Unit $85 + shipping & paypal fees* NOT the fuel pump hanger...
  • For sale 1g 1GA OEM Corner Lights
    1GA OEM Corner Lights $65 + shipping & paypal fees* all mounting tabs are intact * the...
  • Wanted WTB 1990 AWD manual Talon Transmission or shifter Forks
    I need a 1990 AWD 5 speed manual Transmission. The transmission has all the shifting forks...
    • 90rallytalon
  • For sale 1g 1g dashmat. Black.
    1g dashmat. Black. Overall good condition. Does have a tear where the dogear flap is on the...
