Hx40 with paper ID
Diehardmitsu
58
Apr 21, 2011
orlando, Florida
Hey all,
I'm looking to get an Hx40 and found one locally that has a paper tag ID on the compressor housing instead of the the usual metal riveted one.
part number# 404 6104
Any thoughts
if its not on the compressor housing i wouldnt deal. does it even say holset on the compressor housing?
The HX40 comes with a 10 blade or 12 blade turbine wheel. I'm thinking the 10 blade will spool faster...but not sure.
We have nobody who has run the 10 and 12 blade turbines back-to-back in otherwise equally-equipped turbos to know which performs better.
History has told us, however, that less turbine blades on equally-spec'd wheels will generally result in higher flow and more lag because there are less blades there for the exhaust flow to grab hold of. Larger spacing between the blades = less backpressure, so the air escapes quicker.
I've seen where guys have reported the exact opposite with the HX40, but I just don't see it being true.
Thats what I was thinking, less blade more flow especially the on the top end.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
