Hx35 oil leak(feed line)
wesnaiska23
135
Nov 5, 2011
taunton, Massachusetts
i have a hx35 that is leaking from the oil feed that is connected to the turbo. it is leaking between the turbo and the an fitting. i checked and it is tight and i also have a rubber gasket in between there but it is still leaking. what can i do to stop this?
Copper crush washer,
It's
Probably leaking cause you used a rubber thingy. Do you know how hot turbos get? I'm not
At all Surprised
It's leaking most feed kits even come with said copper
Crush washer.
makes sense. i dont know why i didnt think of that :ohdamn:
