HX-35 with BEP T3
efrainz28
169
15
May 27, 2008
Long Beach, California
Is any body running this T3 inlet 3" V-band Outlet on a HX-35?
Specs:
T3 Inlet
.70 A/R
3" V-Band outlet
from BEP. What is the pros vs the cons of not running the .55 A/R with mitsu outlet.
A friend of mine owns one and will be putting it to good use on his upcoming AWD Spyder build. No numbers just yet, though.
Apparently the T3 .70 a/r housing is what's needed to max out the flow potential of the HX35's turbine, although any street-driven DSM will never get close to maxing out the turbine on pump gas no matter what turbine housing you choose.
Base your selection on convenience, compatibility, and availability.
