HVAC controls
galantracer53
172
Sep 21, 2012
schaumburg, Illinois
So I have a 99 Eclipse GS and the HVAC control switch (temp control, fan speed, position) doesn't always light up. It will sometimes but then if I turn any of the knobs or go over a bump it'll go off. I believe it's a ground issue but can anyone tell me where it's grounded to?
Any help would be awesome!
Yeah I'd want it to be solid blue. I think when I'm sanding it off I just won't sand those parts of the gauges and leave them along so those colors won't change
Damn that would be nice to see how it looks ### then I could see if it's worth sanding it or not
Do u have a pic of what it looks like without it sanded through??
No, each gauge has at least two bulbs. The larger ones have three. But I would highly recommend an LED strip for each so you have more light that doesn't have dark spots between bulbs, and it'll be much brighter than just a few bulbs. When I get the LEDs for the white cluster, they will be strips.
Would the blue light go through the yellow tint??? ### I mean from the picture you shied me with the flash light it looks fine to me
The blue would not, because of where it sits in the light spectrum. The flash light shines through because it's white light. I got some blue LEDs, I'll do the same thing with those and show you how they compare. Even with my sanding job, it doesn't shine through as well as a strip would.
Definitely go with a light strip. Here's the pics. The first two pics, is the sanded face, with only one LED. The last two pics is the stock non-sanded face, with TWO LEDs, and even then you can barely see it.
So how would I put an led strip in there??? And where would I wore it into??
*wire
And I just looked at the hvac controls. The red wires are what's causing the problem tested the connector with the black and green wires to it and that's grounded fine and getting power. Now how do u remove the hvac controls so I could fix it??
*wire
You could remove the vents like I did in my pics, and just reach back and pull that part of the connector out. I wired my LEDs into the red section so I could use the stock connection so I could dim them with the dimmer switch.
But how do I get the led strip into the the controls???
And yeah I was planning on wiring it into the red wires so it would still be semi stock. And how would I do the strips for the gauges???
That would be really helpful. I had to post pone doing mine for a few days but I think I'm just gonna do the gauges at the same time too then
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
