How to time CAS
Kyogie12
306
Feb 14, 2010
Boulder, Colorado
Hey, so i've searched around but i want to make sure i do this right. Can someone walk me through the right procedure to time the CAS right on a 1g? My car has been idling between 2-3k and I wanna make sure the cas is right before i adjust the biss.
Thanks!
grab a timing light, aim for 5* tdc and as your timing light is going unscrew the two bolts holding your CAS on and spin it up or down until it lines up....remember to ground out your timing connector....it's pretty easy once you do it once...
