how to set up to use an external wastegate on a tubular manifold?
When buying a new mani buy one with a flange off the collector for a Tial 40mm. Look into DNP they have some nice ones at a good price.
you will have to get the hole in the turbine housing welded closed and maybe a dumptube to come off the wastegate
well depending what turbine housing and 02 housing if the 02 housing is smaller than the outlet there maybe some gain.
You can get something like this...
The pics above are for 4g63 external wastegate manifold with 40mm flange.
If you have funds, you can get this piece below which is the manifold, wastegate and 02 housing. The wastegate is routed back into the exhaust.
The one below is just a manifold, so you can keep your wastegate setup on the o2.
All pics are from http://www.dnperformance.com/eclipse.html :thumb:
yea the last one is one i was looking at, is there any differnce in performance?
That last one that you are referring to, it to be used with either an internal wastegate, or an O2 housing mounted external wastegate. If you want a manifold mounted external WG, then you have to use the the one in the first pic. :dsm:
