Drag Race Build 95 Talon TSi AWD
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
GT30 Variant
Automatic
Build Type
  1. Drag Race
k&n filter, FP 4" intake with custom cold air, FP 3082HTA, E.T.S. 10.5 Pro Race Fmic and short route pipes, Tial Q bov, 1g throttle body, JMFab 2g Drag sheetmetal intake manifold, FP Race Manifold, Tial 44mm wastegate, 2.5" ss o2 housing, apexi n1 down pipe, apexi n1 catback, Fluidyne Radiator, slim fans, ngkr br8es, 2150cc injectors, Supra Denso Fuel Pump, 255lhp inline fuel pump, fuel pump rewire, -8an fuel lines from tank to rail, stock feed as return
*waiting to go on*
bolt in fuel cell, Magnafuel 4303
Mods-Engine
FP4r cams, fp beehive springs, arp L19 headstuds, Cometic HP Steel Head Gasket, titan sce exhaust gasket and turbo gasket,
Mods-EMS & Logging
DSMLink v3, omni 4 bar map(logged in link), plx m-300 wideband(logged in link), , EBC @ 30lbs (controlled via link), Autometer gauges(Boost, Oil pressure, fuel pressure, Oil temp, Coolant temp),
Mods-Drivetrain
Trans mods in the works, solid subframe bushings, solid driveshaft bushings, solid diff bushings, added 4th diff mount, FF rear diff cover, solid front and rear motor mounts.
koni yellows, ground control coilovers (450F 650r), ingalls front and rear camber kit, 15x7 drag dr17's with m&h racemasters 235/60/15's
Parts Wishlist
2.0LR Motor, Curt Brown 2g Cylinder head, ff manifold with a large turbo from FP and track time.
1/8 Mile E/T
7.750
1/8 Mile MPH
95.000
Timeslip Photo Link
Timeslip Details
Track Name : Texas Motorplex
Nitrous : No
Fuel Used : Race gas
Vehicle Weight : 3150
Tires : Street Radials
Sponsored Car : no
340.2 lb/ft
Dyno Type
DynoJet
Dyno Sheet Photo Link
Dyno Shop Name
Abel Racing, Ok
Dyno Session Details
Nitrous : No Nitrous
Turbo : FP 18g-6SL2
Boost : 24
EclipseRacing99
More in 2G DSM
Share this Vehicle
