miliman13
- 2,493
- 693
- Jan 1, 2011
tampa,
Florida
Drivers! .
i have read the threads seen videos that answers half this question. But now i need help on the other half.
i have a 98GSX 1G BLOCK 2G HEAD 93-94 CAS DSM LINK V3 FULL.
i understand TDC "Top Dead Center" 1 Cylinder. then Dowl pins at the 12:00
with the Exhaust CAM facing 3:00 and the Intake CAM facing 9:00 {tick marks}
BUT MY REAL CONCERN IS.(1) i have never done it. (2) and i don't know which belt i need because i have a swap? (3)..also i do not know what order to to start by . (4)were to get this special tension-er tool. "or what it is called" ..
MOST IMPORTANT!!!!!!! of course my timing is off, both cams face to the 9:00 .
But i have to completely turn my CAS 180 Degrees (upside Down) for the car to start. if i don't it wont start. so i cant BOLT the CAS to the head ..... Would this be the reason? (bad timing) for the cas to only work upside down ?
THANK YOU ALL. YOU ARE ALL MY HEROES. SCREW SHADY MECHANICS
