How To quick fix coolant problem temp solution
spooln4fun
642
14
Jul 9, 2005
BELPRE, Ohio
alright my ECT is bad, which in turns gives me trouble during cold starts. I am wondering if there is a "quick fix" as to turn on both fans by just turning on the a/c such as using a jump wire. or some sort of solution to turn on and off with the vehicle. until i get this fixed.
if i unplug the ect it starts just fine everytime. I have serached and read vfaq and know there are how tos but involve a hair bit more time then i currently have. Going to try and fix this during lunch break at work. Thanks for anyhelpWTF
Well, I have my fans turned on by a switch. It's a 15A switch from a local hardware store. I just hooked the power line to the battery, and ran the ground line to the switch, so when you turn the switch the fans turn on. Is very convenient since you can turn them on or off depending on the coolant temp.
Pull the 30 amp AC fuse under the dash so the compressor is diabled
(note this means you wont be using the ac until you put the fuse back in, blower motors also disable)
then turn your ac switch and button on you should see both fans turn on and run as long as you have the switches on
searched and found the above info.
I also know you can put a paperclip as a jumper and it will kick them on but I can't find the info.
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
