how to install a boost control???
gst-turbo
677
59
Nov 7, 2012
Petaluma, California
i have a 1999 eclipse gst turbo that i want to put a boost control on it like this one
but the problem is the waste gate is not hooked on to the turbo it is hooked on to the compressed air a valve gose to it then ther is a spliter on the same valve that gose to the air intake then another spliter that gose im not sure were but i gflowed it and it spored next to the box that the air intake?????? how do i set it up pictures please
Hopefully you have some supporting mods to go with that boost controller..otherwise I'll just patiently wait for your thread asking why you blew your engine.
No offense but if you don't know how to install something this simple you shouldn't be under the hood. Your going to hurt your engine. Take it to someone who knows what they are doing to mod it and TUNE it.
Man it doesn't make much sense whatever you are saying. Pretty sure you are talking about the stock boost controller solenoid can you take a picture of it?
The stock system it has a hose that goes from the compressor side of the turbo to a T that splits to the actuator and to the boost controller solenoid and from there to another hose that hocks to the rubber intake before the turbo.
Check this out it might help you a lot... http://www.dsmtuners.com/forums/articles-miscellaneous/198327-taboo-speed-shop-vacuum-diagram-removal-1g-2g.html
And as stated above do not raise boost with knowing what are you doing start with a tune up first if the car is new to you.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
