Need to Pass NY Inspection - Boost Control Solenoid
gophishy10
350
7
Apr 17, 2012
Boston, Massachusetts
So I just replaced a bad ECU to get rid of a CEL for MAF Sensor. Now I'm getting a code for wastegate/boost control solenoid (P1104). I did a lot of research on this and found out that when you have a MBC you still need to have the stock boost control solenoid plugged into the wiring harness for there not to be a CEL. Apparently, the last owner decided to get rid of the stock one when they installed the MBC. I've done hours and hours of searching for a stock solenoid and cannot find one anywhere. Anyone have any ideas? And would something like this possibly work? (only wiring hooked up, no vacuum lines).
Boost Control Solenoid valve BCS MAC 35A-AAA-DDBA-1BA, turbo PWM EMS ECU | eBay
You could go to a junkyard and look for one. That or hit up the guys at Miller Import Parts for one. I am 100% sure they have one or can get one.
Their Facebook link: https://www.facebook.com/#!/SandMAutoParts
Thanks! I wrote on their wall and am waiting for a reply. I appreciate it!
Look on eBay for justjap imports or TAE imports. They are both in Florida and deal in used ### parts......even though the DSMs are not imports. You could also check JNZtuning.
