How to get 375 hp the most effiecient way
tjharris
Nov 9, 2008
Greensboro, North Carolina
Hi guys I have a 1995 eclipse GST and I was wondering if anyone had any ideas for me to Push atleast 375 For the cheapest but efficient way. Wwhat parts I should get and what name brands are the best for eclipses.
Follow the upgrade path.
Honestly you have a lot of reading to do in order to hit 375hp and even more if you want to do it reliably.
If you want 375hp though you will need dsmlink, or a standalone for tuning.
Large injectors to pump enough fuel, you'll have a good tuning system so you might as well go big, 950s would probably get you somewhere.
More fuel out of the tank, I'm not sure if a single warlboro 255 will do it so you might need two.
A 16g turbo can get somebody into the 10s but 375hp would push it mightily so you'll have to look at the hundreds of choices of turbos out there for a good balance of spool time, power, and price.
Of course you'll need exhaust, once you have your turbo figured out get a 3" turboback system from a local muffler shop.
You'll need to breather better too with a cone filter and solid intake pipe.
Some cams will help the engine push a little more out you'll want 272s probably.
An intercooler will help finish it off, a good front mount should do the trick or if you want to keep a sleeper look then a supra sidemount ought to still be able to keep up into that range.
Honestly there is a lot more besides that list but it gives you an idea.
Of course don't forget that unless you take your time to learn why I suggest all of these parts you'll need some money to have someone tune it for you.
Also set aside some money so that you can get the car to stop once you've put money into it, expect about $2000-$3000 for that.
A meth injection kit will help you keep the knock down.
Finally, I have to ask if you've really thought about your goals, what are you going to use this car for? Will you ever use it on the street? Is 375hp just a number or do you have a time that you want to hit?
You can have a 375hp car an still only be able to run 13s on a good day so more information is good and you'll still have to do more reading.
Did I mention you need to do more reading?
Start here.
Tech Guide: 2G 4G63t Upgrades - DSMtuners
I would say a 16g with a cheap e85 setup would be a good way. I dont know if there is e85 close to you but I think there is some stations up in NC.
    • Sdcryan1
