2G How-to: CTS-V Big Brake Kit on 13" rotor for less than $600
Anyone with a 1g use a 17x7.5 +42mm offset wheel?
It sounds like with the CTSV brake adapter it'll move out 5mm to +37mm. Is that enough to clear you think?
What is the braking distance outcome, very noticeable from 60+?
I know this is old but where did you find the hub rings in? Only ones I can find are in China and will take 6 months to get! Noone else has 70.6mm to 67.1mm rings
So I've been reading around and apparently nobody really has ever responded most of the questions regarding this conversion and what needs to be done throughout some of the threads I tried to use to make this happen. Either they didn't know or weren't kind enough to share once they have achieved it. I have also been getting a few questions regarding my setup so might as well as clarify a few points:
Many question why I decided to grind down the mounting tabs instead of adding a spacer. The 5mm spacer is an option but there are a few reasons I decided against it.
1. It pushes the entire rotor, wheel assembly outboard by 5mm. That would have made my 17x9 35mm offset wheels into a 30mm out font and changed my trackwidth in front only. I already have difficulty with wheel fitment into the wheel well. I didn't want any more.
2. A 5mm spacer is pretty big and usually wheels are setup as a hubcentric item (it centers to the hub outer lip) which relieves the load from the studs. With a spacer behind the rotor hat, that space for the wheel to rest upon would disappear which for somebody who will see occasional track use with this car is not the best scenario. I checked the thickness of the calipers and how they were designed/reinforced and based on my years of design experience I can say that the reduction of 5mm from the face of the calipers will not affect the structural integrity greatly.
3. This method provides more clearance to the wheels. We all know the struggle to fit BBK's on 17" wheels. This install moves the caliper 5mm inboard which helps provide more clearance to the wheel. If I didn't have that clearance I would probably still be fine but some people aren't as lucky.
4. "I ready somewhere/someday that a guy removed 10mm, why 5mm instead of what he did?" There is no need to remove 10mm. That is overkill and reduces the rigidity of the calipers. Reducing 5mm will center the caliper perfectly to the rotor. Measure twice, cut once...
5. Note that this is not a diss to anybody that has done it differently. I have my reasons to do it this way and wanted to keep it as economical as possible without cutting corners. I believe I have achieved this.
Also note that this is for the 2G DSM. It might be the same process for the 1G but I cannot confirm it.
Things you will need:
1. 2 CTS-V 4-pot front brake calipers 2004-07 = $300 approx
2. AC Delco 18K1971X Brake Caliper hardware kit = $20 approx
3. 2001-02 SVT Cobra 13" rotors = $38 each from an auto parts store
4. Brake pads = Here it's really dependent on preference. I chose Akebono's Street Performance, but you can pick whatever you want from either a Caddy or an Evo VIII-IX. $88 for Akebono's
5. Banjo SS Brake lines = Some DSM's have direct threaded lines, others have banjo bolts. If you have banjo you can actually reuse yours. Lines can be found for $60 online (fronts only). I suggest getting Evo VIII or IX lines as these are guaranteed to fit. You can also get Cadillac lines.
6. 67.1mm to 70.1mm hub centering rings (2 only). = $25
7. Brake fluid = $10
8. Qty 4 - M12x1.75 x 25mm bolts and locking washers. = $10
Total = $595. You can get better deals. Just as an example I got everything except for the lines (already had them) for $375 all brand spankin new. Shop around, use coupons whenever possible and you will get deals just like I did.
Part numbers and everything is in the attached images. Those PN's I guarantee will fit this setup. Anything else you're on your own.
Optional parts:
8. 2mm Ti Shims set of 4 = $180
9. Wheels... This should be a given but OEM wheels won't work. You need 17" wheels preferably on the 17x8 to 17x9 range. Wheels that fit, do your research. I can vouch for Kosei K6r's on 17x9 35mm as that is what I currently have.
How to mount these up:
1. You will need to grind 5mm from the mounting tabs. You have to grind perpendicular to the bolt hole. If you are unsure on how to do this or do not trust your skills, any competent machine shop can do it for less than $50. I chose the DIY route and using a dremel and lots of patience grounded it down. Measured with a micrometer during the process and got it well within acceptable tolerances. The final result of thickness should range as close to 70mm from opposite sides of the bolting tabs as possible. I got mine 70mm +/-0.130mm and it works perfectly. See attached picture.
2. The Hub centering rings will go before the rotor. Install the centering ring and then the rotor hat. Mark any excess protrusion of the rings and grind down with either a dremel, file or grinder. They should be as flush as possible to the outer face of the rotor hat.
3. Install the rotor and calipers as you would install any other brake assembly. Lube every contact part and bolt and install securely.
4. With a caliper, make sure the rotor outer and inner edge are at 14mm from the centerline of the calipers (where the two halves unite).
5. Bleed out the system.
6. Enjoy the braking power.
Now you will notice I mentioned optional parts. These calipers are made for a 32mm Cadillac rotor and the SVT Cobra rotors are 28mm. Adding 2mm Titanium shims on both sides will get you to the 32mm OEM range in terms of piston to rotor engagement length. The reduced thickness rotors work fine without the shims, but if you want to reduce brake pad kick-back (if you road race, autocross, etc) then this will get you there with the added bonus of more heat dissipation.
You can select other rotors out there and make this swap as cheap or expensive as you want but I am giving out realistic numbers on what to expect on account of cost.
Now let the bashing/commenting begin!
Cheers :thumb:
Not sure if it applies to anyone else but I've all but completed this swap however I need extended wheel studs now. Just be aware for anyone who is doing this swap. Depending on what wheel bearings are on your vehicle you would need either ARP 100-7717 or ARP 100-7708 and consider open ended lug nuts depending on your set up
Has anyone tried to put Evo X rotors (350mm / 13 3/4)... Cut them to a diameter of 13" or 12.99", and use them with the CTS-V 4 piston Calipers in a 2g? Will the 5mm spacer or 5mm ear cut be still required?
Do you guys think my Rota 17x8.5, 72.6mm Hub, +45 Offset will fit?
We're looking into this.
We've got all the parts here to do a mock up, we just have to find the time. We'll probably have some results soon.
We've looked into this.
It looks like the centerline of EVO 10 rotors would run about 3mm more outboard than Cobra rotors. This means you'd need to accommodate another 3mm of outboard movement (either with a 3mm spacer or by removing 3mm of material from the caliper). This means it's possible to run with a modified EVO X rotor with no spacer at all, just a modified caliper.
We may end up offering both solutions:
1) Cobra rotor with a 3mm spacer AND 3mm machined off the caliper.
2) modified EVO X rotor with 3mm machined off the caliper.
We're looking into these 2 options now. It still requires crunching a few numbers to see if it's economically viable.
Forgot to mention there's another benefit to running EVO X rotors: they're 32mm thick (as opposed to 28mm thick for Cobra rotors). 32mm matches the thickness of the Cadillac rotor the CTS-V calipers were matched to, so there are no issues with the gap between the pads and caliper pistons.
@Paul@RTM @AndrexZ
I have probably done the most extensive work with ctsv brakes on the forum. It was years ago now so I’ve forgotten a lot of it, but it was significantly more work than expected. MOST of the problems I ran into were due to the 14” diameter though so turning them down to 13” will make it drastically easier. I suppose I can’t really help much with the details if the intent is to bring them down to 13”, but making a bracket that utilizes the factory ears and the rotor in 14” required a ton of work to keep the pads axially aligned about the same center point of the rotor. I spent a few weeks making different brackets, mocking the entire knuckle up un cad and trying a handful of caliper castings and rotors. I posted about it somewhere on the forums but I am terrible with pictures and whatnot so I can’t provide much help.
Economically, I can’t see it being any better than a cobra rotor, but if there were a magic rotor out there that had an evo x offset in 13”, it would be the best rotor. It’s wider, has a better offset, and has more aftermarket options available. I want to say there was also a an oddball 90’s model porsche rotor out there that was even better, but you could barely even find the rotors cause they were not used on any cars other than that one porsche.
I was damn set on having 14” rotors for some reason at the time so I ultimately chose to machine the knuckle and use a different style of bracket.
Other brackets
Here are more details on the mount and how I drill the rotor in order to do a better fitment on this setup... Also more pictures of the back part and how the Evo wheel fit on this Brembo setup... Thanks so much for the instructions and know how to by this Post... I just made it possible by this post so here is my contribution
nice post, how are the lines holding up. I’m working through this now but it’s awkward how the lines go in the back, I think there is another option to swap the crossover tubes?
have custom lines made and they can make a banjo with a different angle ready to bolt up and make it ALOT better fitment wise and less strain on the line
Thanks for all of this info on the swap. I just wanted to add that Dorman 13898 caliper bolts are the caliper bolts to use. They have a slight shoulder that interfaces with the knuckle mounting hole, and the bolt goes the entire depth of the caliper bolt hole with no poke through.
