How to change condenser???
sadc
274
Feb 17, 2008
Kapolei, Hawaii
So I just bought a 4g63T gsx 2g car....a/c does not work....upon refilling I seen all the freon coming out from the condenser. And straight through my fmic... So I was wondering if I can swap out condenser from my 420a parts car( which the condenser was working but the some wire wasn't working) into my gsx? Also How to I take it out? Looked at the manual, and it showed nothing.
I'm not sure if the condensers are interchangeable but it is fairly easy to take out.
1. Take off the top and bottom radiator hose from the radiator.
2. Take off radiator brackets
3. Take out radiator
4. There are two 12mm bolts on the frame to take out.
5. 2 12mm on the bottom to the support
6. take off both lines that connect to it
That's pretty much it, I know I forgot little things like the condenser fan connector and stuff but its basically it. Pretty simple.
    • dsmmario
    • Canadian_CD9A
    • my98gsx
  • For sale 4G63 Six bolt cy head. Ported. SS O-rings. Ferrara valves.
    Six bolt cy head. Hand ported and flowed by Baker Cylinder heads. He started at Air Flow...
