How much would my 91 Talon tsi awd put down?
Status
Not open for further replies.
91Tessy
Jun 10, 2011
Lincoln, Nebraska
. Motor was rebulid about 25,000 mile ago with 8.5 :1 2 g oversized pistons. forged connecting rods. has a balance shaft removel kit and numberous power coated parts. Exedy 3 puck sprung race clutch was also put in. Fuel system includes a walboro 255 fuel pump, a SX pressure regulator, braided stainless fuel lines. The exhaust a 16g turbo, custom front mount inter cooler, a tial external westgate, 2g ported exhaust manifold with polish cover. It has a roadrace enginering downpipe and O2 eliminator with a thermal catback exhaust. Power slot vented rotors with Axxis pads on all four corners, 3 g lifters... 11 psi. Thanks
You should probably take it and put it on a dyno. No one can tell you how much power u have because no 2 engines are really the same. Not trying to be smart just saying..
First fill out your profile with said mods..Second I don't see injector size, block bore, actual piston size, and no tuning device..I also don't see the use of head studs, or anything..And 11psi, come on man..
Third..This will be moved eventually to the bench racing thread im sure of it..Or It will get deleted..One of the two..
Well since it has "numerous powdercoated parts" and "braided lines" it should put down "massive" power.
Seriously though, if your going to mod the car, just spend the money to take it to a dyno. Also, please read the rules of the site.
You forgot to take in to account the polished manifold cover and the powerslot rotors. That is at least another 30-4- HP to the wheels.
Take it to a dyno. We can't calculate your horsepower- you can bolt all the mods you want on the car...if your tune isn't perfect you'll make less power than a stock car.
Bench racing threads are not permitted in the tech forums.
I wouldn't even waste my time with 11psi, by the way. ;)
Status
