How Much PSI
eric91gst
163
May 30, 2006
Sylvaina, Ohio
hey guys i was just wondering how much psi I could run safely with 550 injectors. I have a evo3 16g and a wallborro 255 pump. I know i should get an safc but i just wanted to know how much boost i could run without having to control the injectors. Also how bad would the car run if i ran as much boost as i could with that setup and didnt have an safc.
-thanks
Don't even try it without fuel control. It will do more harm than good.
Also, you should work on getting an AFPR for that 255.
EDIT: Please fill out your vehicle profile. It will help us recommend and troubleshoot. Do you have all of the other supporting mods for a turbo upgrade?
Then you are overrunning your stock FPR. Do a search on the 255 and you will find alot of discussion about it. Its not a recommendation. Its a must.
It is also a must for fuel control to control anything other than stock injectors.
Don't skip steps in the upgrade path. Get the correct mods in the correct order and you will be much happier in the end.
If you go the SAFC route, then you are still going to need a datalogger to see if you are running lean or rich, and to read knock.
eric91gst said:
what happens if i dont get that afpr and just get an safc
It would suck, but how do you plan on adjusting the safc without a logger anyway?
edit: Damn you Shown. :)
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
