How much power will a 4G64 block hold
Clipso 1
42
Sep 3, 2003
Im trying to figure out how much power a stock form 4G64 BLOCK will hold, not the parts inside the block, but the block itself. I am going to be buying all the other parts later but for now I need to see if I need a custom built block or not.
Thanks,
Jeremy
Since the cylinder walls are thinner than a 4g63 block you'll have to consider when or if you'll have problems with the cylinder walls splitting. I'm guessing the limit of a "stock" 4g64 block might be in the mid 800hp range.
In a race application you could fill the blocks coolant passages and make it more reliable.
