How much Compression?
philly90tsi
30
Apr 28, 2005
philadelphia, Pennsylvania
Hey I posted a couple weeks ago - "One 1g won't kick over" Anyway, im about to do a Compression test and I wanted to know if any1 knew how much Compression you need in each of the cylinders to run our Cars?
All feedback is Greatly Appreciated! Thanks!
I did a comp check on my N/T and pulled 186-189-178-187 I don't know if that will help but it gives you some kind of idea.
Service limit is 121, but it will "run" with much less than that. Doesn't mean it will run very well, but it should still start up.
Yeah im not even starting at all- I checked fuel it squirting.... I did the ether in the t/b and i got no dice. Im getting Spark also.....I thinking a time traveled or somthing! maybe the belt Skipped a tooth>? It's driving me Crazy! Only time will tell! Thanks for your input!
