How much more boost?
I would get a logger before doing so.
I ran 20 psi on my 2g (with a 14b) with a 255 high pressure fuel pump as my only fuel mod.
my friend was running 25lbs with a stock 4g63 but then the turbo gave outLOL you could safley run around 18-20lbs without any problems for a ltitle while
Get a datlogger, don't listen to everbody else's opinons, they don't know what they're talking about.
My car knocks above 14 psi with stock everything, so I would definately get a logger before you consider turning it up anymore. Listen to the two guys above me.
You can crank the PSI as much as you want, there is just a direct coralation between how much boost you put in you car and how much $ your going to put in your car to fix it. LOL,... but seriously it true
BTW, 93 octane dies out at around 20 psi. I wouldn't go 18psi w/ stock injectors unless fuel press. was raised. Oh yea, a logger is nice:beatentodeath:
