How much hp can a Stock automatic awd transmission handle?
pyanac711
109
Feb 21, 2012
hazle township, Pennsylvania
I'm just wondering what a awd stock transmission will take? I searched and couldn't find anything and was wondering if anybody could help me out. With a good tune my car will put down 550+ awhp. Car is a 1995 talon tsi awd with a built 6 bolt with the stock 1995 talon tsi awd trans. The tranny has 75,000 miles. I plan to have a tranny built for next summer. Thanks!
In theory it could handle that, it might not though. You will break it real fast launching it improperly and slamming gears, but just putting power thru it isn't going to kill it as fast.
-Manley I beam rods
-Wiseco 9-1 pistons
-ARP main studs
-Lightened and balanced crank
-BSRK
-Cosmetic head gasket
-Oil pan ,oil pick up pump,water pump, timing belt, timing components new
-Stage 6 CNC ported and polished head
-Ferrera stainless valves
-Ferrera springs
-Manley titanium retainers
-Comp 101400 pro race cams
-New revised lifters, rocker arms
-Bronze guides
-5 angle valve job
-Fluidyne aluminum radiator
-FAL slimline fans
-Prothane engine mounts
-DSMlink v3.0
-Blitz turbo timer
-battery relocation kit
-SBR SS tank to filter, filter to rail ss braided line kit
-Fuelab 515 complete kit
-1000cc FIJ Injectors
-AEM fuel rail
-Walbro 255hp Fuel Pump
-Kiggly 6olt-7bolt trans adapter
-RRE Cam wiring harness
-4" SS intake pipe
-JMF Race SMIM
-75mm Mustang TB
-3.5" GM MAF
-28.5"x10"x3.5"short route FMIC
-Turbo XS HP MBC
-Autometer 60psi gauge
-Autometer WB AFG
-Holset HX40 Pro turbo
-SBR ported cast exhaust manifold
-Tial 38mm external wastegate w/ dumppipe
-Greddy BOV
-Apexi Turboback
-20,000 GVW trans cooler
-CF hood
-2gb Talon F/R Bumpers & Hatch
-CF fenders
-CF doors
-Bride Low Max seats
-Sparco Harness
-Complete silver zurilic marble interior
-Veilside steering wheel
-CF center console
-CF kick panels
-CF a-pillars
-CF door cards
-Black carpet
-Evo IX wheels,Bridgestone tires
-K-sport Pro Kontrol full adjustable coil over suspension
thats what the car has done to it so far
Depends here on the condition of the trans, and the purpose dont think there is a good number, things will eventually break depending on how you use it. You can always have it built for your purpose for the car and have some ideas. A stock transmission with that much hp maybe not long.
what do you have done to it?
Running full line pressure, good fluid, and a larger cooler will help it survive longer. Like others said it just depends on the condition that it is currently in. If it was abused (fluid and filter never changed) then it won't last long and the clutches are probably on their last leg. Mileage doesn't really matter.
the list whats done to it is posted above. the kid tht had it before me took good care of his cars.
So the only thing done to the trans is a larger cooler? I'd look into getting a shift kit, reprogrammed tcu or a shift box or blue wire mod. Also a different torque converter and flex plate.
My auto was abused before I got her and I missed a fluid change :( I destroyed everything in my Trans. She's got about 350awhp. Now that it's rebuilt with blue wire mod, kiggly gears, higher stall and valve body mods she handles great!
My Trans also had 208k tuned in 23psi when she blew LOL
Good luck! English racing has a guy do their autos and he's fricken awesome! Decently priced as well. Metro Trans FTW :)
