How many cans of primer should I use for my bumper?
I assume you mean spray paint?Get high build in the auto section at wally world.1-2 cans. 2 would be good for putting on a couple coats
Well it doesn't have to do with how many cans but it is coverage and comfortability.. I put two coats of FLEX PRIMER on my front bumper than 3 coats of white.. I ran out of clear coat so i need to strip it down alittle and add more clear.. Make sure you use a flex primer on the bumpers or the paint will crack. They also make an additive for the base so the paint is extra flexible
edit- oo your spray painting.. Umm try what he said.^^^
personally i would just save youself the headache and buy a quart of primer and spray it from a gun. spray can always looks good at first but 2 or 3 weeks down the road will look like shit imo
well the main intension is to shaker can primer and use the gun for the real paint coating
dude you dont want to paint your car after you rattle canned it. Ask any paint and body guys.they will tell you the same,just trying to save ya a headache
to answer the OPs question, zero.
Go buy a paint gun and head over to your local body shop. Buy a quart of primer, base, and clear and all the hardeners and proper reducers. I bought some mid grade stuff from sherwin williams and it only ran 150 bucks. I had enough to cover about half the car. one quart of each should paint a body kit. Just remember that all the prep work is whats gonna make it look good.
Also, the reducers in your base coat are gonna mess up the rattle can primer. Thats another reason not to touch a rattle can.
if you have the time and money the best would be with a compressor and gun, if you do it by rattle and take it somewhere to paint it later, they are just going to undo what you just did.
Last year i did that to my car, and this winter its getting striped down and done by a gun, because after a month or too, you get the multi-gray-ness primor effect LOL, looks killer wet but after it drys, you can tell the different shades of black LOL.
gotcha ima try n get a gun and paint it otherwise im gonna have to take it somewhere to get it painted
actually I do paint and body work at my shop and there's no reason you cant primer with a rattle can and spray with a gravity gun after. I use a good filler primer so it fills and blends any kind of defects that I cant get 100% of, then sand and spray the color. sand again, spray clear. DONE
