How high can you go?
jasoncitrano
600
Jul 10, 2004
schaumburg, Illinois
How much boost do you guys think you can safely run on a evo III with stock internals and 680's i'm at 20psi right now, also how can you tell how much higher you can raise the boost with race gas?
can you run race gas and raise boost a little at a time and watch the knock to see how high you can go without getting to much knock? or what?
Depends on condition of engine, type of IC, how good you can tune, octane of fuel, ambient temp, what other kids of mods you have (cams, smim, nitrous, etc). Start conservitivly and watch things with the logger, and remember too that more boost doesn't always mean more power.
i have a pocketlogger...just need to know what i'm looking for, like what kind of problems i would see when i start to run to much boost.
i have a ETG, datalogger, a/f gauge, safc II, and blue wire mod done. right now when i show knock on my afc, it says 0%, but when i go to actually see knock it's up around 23 or something like that? how do you read it? i was told that 23 or so was so small of a percentage that it wasn't going to show up on the afc yet is this correct?
saw wave analog said:
knock and timing retard. get an egt and a/f gauge too if you want even more security, fuel pressure is good as well
A/F gauges are useless dont go by it.
Just go by the knock count that is on your PL not on your S-AFCII
23 is too high
after 7 counts of knock the ECU starts to retard the timing of your car.
Read up the basics of tuning. It sounds like you need to learn the basic laws of tuning.
Read some of this
http://www.roadraceengineering.com/newafc.htm
and this
http://www.pocketlogger.com/forum/viewtopic.php?t=143
awesome, thats what i wanted to know thanks...also how accurate is the safcII at displaying the knock sensor values?
this seems to be the common sentiment in dsm land, and for the most part they are useless for precision tuning purposes, i will always run one though because its just one more way of knowing that something is wrong. vague or not, if it shoots down to .85 volts you know you are about to blow something up so you get out of the throttle.
a bright, bargraph or single led style one like dawes device makes *is* indeed a quite useful indicator
