ECMlink How does this E85 log look?
Marchev
386
75
Jan 31, 2009
Niles, Illinois
Hey guys, so I just switched to E85 yesterday and did some tuning this morning. Let me know if you guys see anything concerning. I am aware of the 2* knock I got just before redline and that will be straightened out. Mods are up to date under profile. 24psi boost on E316g, LC2 wideband logged, targeting ~11-11.3 or so at WOT
PS Any idea why the E316G is only logging ~27lb/m at 24 psi boost? I'm probably wrong but I thought it should be in the high 30lb/m by now?
Thanks for your input!
Your Global fuel and deadtime are off. Look at your boost EST its reading 8psi when you say your running 24psi. I would start with -34 global and 300-400 deadtime. Make sure you lower the boost and timing and readjust the MAF comp table try to line up Boost est and A/F est. You will need to add + compensation across the whole board. This should bring your boostEst up closer to your actual boost. That in turn will raise your LB/min numbers.
I also just noticed you have a -17.2 on your global scalar. That means your starting with -17.2 on all points of the MAF comp table. I would reset that back to 0.
I chose to try to make afr/afr est line up since I read getting both is hard, but ended having boost est and actual boost be very close also, running speed density. Also you may be getting knock from being t0o rich up top, you go below 11 afr at high rpm. try to lean out to 11.5-12.0 and the small traces of knock may go away.
I think you may be right about the rich knock, Ill lean it out tomorrow and see how that works out.
Thanks for clarifying why my airflow is so low. Ill try to play with it more to get the boost est to line up with actual, but I am afraid it will throw my afrs off
It looks like if you just get rid of that 17.2 scalar and fix the global and deadtime your maf comp curve should stay the same. Just start rich and work your way back down.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
