How do you wire th ac slim fan
power=dsm
268
Aug 22, 2003
On my 1g talon, the stock fans would both come on at the same time. Now that i've upgraded to slim fans, my condensor fan only comes on when i turn to ac switch on, and not when the radiator fan turns on. I have both fans wired to their stock locations. I know i can wire the condensor fan up to the radiator fan but i think that would be drawing to much power on that wire.
How do i wire the ac fan to it's stock location so it comes on with the other fan, like when stock?
Both of my 12" and 9" are hooked up to the radiator fan harness, it's been two years now and has never blow a fuse yet.
oldman said:
Both of my 12" and 9" are hooked up to the radiator fan harness, it's been two years now and has never blown a fuse yet.
So you wired it that they both run on high setting?
I knew about the faq, but i was just wondering why they both came on when stock, but now that i changed them only it doesn't happen any more.
Yes, I was expecting to overheat after my fmic installation while retaining my AC core but it never happened. :sneaky:
Something was definitely wrong if they both came on at the same time when stock, the AC fan should only come on when the AC is turned on. Perhaps the previous owner had already re-wired it.
