slim fan question
awdwhip said:
what size slim fans can you fit on the radiator? i want to use two. simple question guys.
I am using 2 slim fans from SBR. One 12 inch and a 14 inch. The 14 inch is located away from the turbo. And the 12inch is in front of the radiator. I removed the ac condenser. The 12 inch is pushing air into the radiator and the 14 inch pulls air out off the radiator.
:thumb: :thumb: :D
You can fit 2 12" slimline's or 1 12" and 1 14" depending on the size and placement of whatever turbo you are using. I currently only run 1 SPAL 12" and I have no cooling problems w/ a stock radiator and my FMIC. Although, If I ever get around too it, I am going to add another slimline to the front of the radiator to push air through as the other pulls, for added flow.
