how do you release the brakes?
1990AWD
Supporting VIP
8,541
26
Apr 27, 2009
Langham, SK, Canada
is there a way to release the brakes? I think they're holding me back because I should be able to push the car when its in neutral on flat ground but something feels like its holding it and the car lacks power.
My awd is always a pure pain in the ass to move on flat land. A little downhill is all it needs to push like a geo metro.
The brake system shouldn't have any pressure on the pads without your foot on the brake. Is your ebrake sticking? Get under there with/without the tires on it and have someone else pull it up and release a few times.
With all 4 wheels in the air you should be able to turn the wheel with some resistance, there's a lot of things to move!
well I discovered my front passenger brake was seized. I tried to jam it loose as best as I could and it really made a difference. I'm also gonna reset the timing belt for the fourth time just to make sure thats right...again.
Last time my AWD was hard to roll around the drive shaft u-joints were toast. After replacing them the car rolled really easy.
If yours doesn't then something is creating drag, be that the brakes, rear diff, driveshaft, transfercase, center diff, etc.
I know I have to replace the brakes and will as soon as I can afford to, but is there a way to tell if the u-joints are gone or if there is a problem with the t-case and/or rear diff? I've freshly changed oil in both.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
