How do i tell if i have a six bolt swapped into my 2G
ChrisTheBuilder
75
Jan 8, 2012
Wichita Falls, Texas
I just had the oil pan off my car the other day and compared to a picture of another bottom end that someone said was a six bolt mine looked completely different.
i have the cam sensor, what is another way i can tell?
Look at your oil pump. On the base of the 6 bolt oil pumps, where the pump and oil pan meet, is will be flat. On the base of the 7 bolt oil pump, it will be round. http://www.dsmtuners.com/forums/maintenance-repairs/412359-6-bolt-oil-pump-7-bolt-block.html
look down about half way and you can see the difference.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
