How do i tell if its a 6 bolt?
94_eclipse
153
Jan 19, 2007
Shelocta, Pennsylvania
Im going to be looking at a 91 gsx and the owner said that it had an engine swap because the timing belt broke so he just put in another engine. He said he is not sure if its a 6 bolt or 7 bolt engine. I want to make sure that it is a 6 bolt or I wont buy it. How do i tell? I heard that the oil pans are different? Any pictures or tips would be helpful. thanks!
check the oil pan under the crank pull the oil pan should poke out instead of recess in.....if that makes since
  • Wanted 6 bolt NT water pipe
    • chrisman287
