How do I know If my oil pressure gauge is shot?
94Talon2
271
Aug 1, 2002
Edm,
Last week with my new stroker 6-bolt, My oil light would come on only at idle(only when hot) , and I had almost no pressure at idle. However If my pressure gauge would go to halfway when reving over 3k rpm.
I decided to put my old 7-bolt engine back in with 2g pistons (due to lack of $)
anyways I'm having the same problem. I figure it's very rare to have the same problem with both engines(different oil pumps). But on the other hand I thought If the pressure gauge is shot it wouldn't read at all.
install a mechanical gauge....a really cheap one at Walmart is $6.
Or get an autometer for 50
or spend more if you want to.
Also get a copper tubing install kit, better then the nylon tubing normally used.
