How do I get the timing sprocket off?
arsgst
37
Mar 10, 2010
Tampa, Florida
I need to remove the timing sprocket from the crank to change the seal on my 4g63t Whats the easiest way to get it off?
Anybody?
Anybody?
I have not had any trouble taking off the crank sprocket the times that I have done this work, usually after removing the bolt, the sprocket will just come off although sometimes it takes a little working it side to side to get it loose…
But if I did have a problem getting it off, I would have used a Puller to remove it. If you do not have one the correct size, an auto parts store like AutoZone or Checker will have them for “rent”…
Hope that helps and good luck!
It's been a while but is'nt there some threaded holes on the crank sprocket? If so use some long bolts and thread them into the holes opposite from eachother. use 4 bolt holes if you're paranoid. Just thread them as evenly as possible, and once they bottom out against the crankshaft it will pop right off. Good Luck!
If you have an old pulley. Bolt it on and slighty hit from behin while turning it and t uh g and pull side to side with it on
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
