how do I get rid of the CEL code p443
Tamatalon39
78
Aug 20, 2011
Robesonia, Pennsylvania
it looks like the PO removed the EGR setup. frim what I can tell being new to these cars while attempting to do a 6 bolt swap. so now while trying to trouble shoot my (not idling with 550 injectors issue) in another post, I would like to not see the CEL if at all possible. also I am not sure where exactly the EGR valve is and if they properly removed and if it is sealed or not, so can someone post a pic of what exactly need to be plugged up and yes I did a search.
do you have link? If so just go to the dtcs tab and uncheck the evap/egr/mdp and misfire detection and all should be well save to ecu and clear codes
I guess my reply didnt post. If you have link go in the dtcs and disable evap/egr/mdp and while ## there disable misfire as well.
