How do i get rid of my stock air box?
94_eclipse
153
Jan 19, 2007
Shelocta, Pennsylvania
I have a 94 Eclipse and it has a Weapon R intake pipe and foam air filter. I want to get a paper filter and get rid of the stock air box. Mostly for better air flow. I am not sure how to get around the MAF. Since it is part of the air box, i am not sure what to do. I know some companies make a air filter that the MAF will fit into but i do not feel like paying 60 bucks for a paper filter. Any sugjestions?
Yeah i believe the air filter is stock, if not its pretty close. I know i gota keep the MAF but i also know that people have clamp on paper filters and have taken out the air box... im just not sure how. Thanks for your help
There are 3 bolts around the air box connecting it to the car. Take those three bolts out, then unsnap the 3 retaining springs from the MAS that connects it to the airbox. Remove the air box(you may want to remove the entire intake pipe when doing this, its up to you. Then keep the filter over the MAS and take those snap springs and clamp them down on the edge of the filter. You weaponR intake needs to connect to the MAS outlet anyway, because its still the outlet of the stock air box, so fitment should not be a problem.
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
