How Do I Connect This LOC To Factory Radio?
NeWyoRksPLaYaZ
265
Dec 6, 2011
NY, New York
hey everyone, i just bought this line output converter and when i opened it i noticed that there arent 4 wires coming out of it, only 1 black wire with a metal stub at the end. according to this write up (http://www.dsmtuners.com/forums/art...-install-subs-your-stock-headunit-system.html) there should be 4 wires coming out of the box. I memorized the write up and know how to do it but how would i connect it to this LOC? any help is appreciated! thanks
Those are very simple. the A side is your input from the stereo. Your B side is the output. Those RCA output are what you would want to plug into to your sub amp. Then your going to switch your side post to "LINE OUT" That should activate the RCA's. then run the RCA's to your amp. Im guessing you know how to wire an amp, so its simple from there.
    • george bromwell
    • pma1123
    • Sdcryan1
