how do i check intercooler for leaks?
97spydagst
268
May 14, 2004
Burley, Idaho
hey guys i searched and couldnt find it how do u check intercoolers for leaks?? i have a big boost leak and have searched everything but the intercooler any ideas thots????????
There is a tech article on doing a Leak-Down test.
They also show you how to do it on Vfaq.
I'll grab the link for ya, lemme go find it.
Checking it like the above posted link would be the best method, as you are checking everything as a complete setup. If you are having problems locating the leak, mix up some water with some dishwashing soap & put it in a spray bottle, then spray all the possible leak areas, if there is a leak you will be able to see some bubbles. If you did just want to check the ic you would still basically use the same method, block off one end of the ic & pressurise the other. If you don't have a gauge to verify if there are any leaks then you could just submirse the ic in water (this is assuming its off the car) and look for bubbles, indicating you have a leak.
i usually just fill it with water and swish it around a bit. if water is coming out of some place it shouldnt be, then you know you've got a problem. also might wanna use gasoline to do this because then it will also clean out the IC while you test it for leaks.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
