How could it seize?
Macspsi
165
8
Nov 12, 2011
Cumberland, Virginia
Here's the story, recently replaced headgasket, water pump, timing belt, and put in arp head studs. I've been easy on it for awhile since I put the 16g on since I did not have a tune, but I was only running 12lbs to be even more sure I wouldn't hurt it. Last week I was coming home, I slowly eased into it and watched it build to 10lbs and it was pulling pretty good :hellyeah: and then it blew a coupler off. Thought that I had tightened it up good enough. It cut off of course and I just coasted it into my driveway and let it sit because I had to go back to college. Yesterday I went to start it, and it didn't sound right almost like a clicking when the motor was turning then it locked up. I have no idea what could cause this, good oil pressure, fresh water pump. I know it couldn't have sucked up a rock when the coupler came off because it was on the j-pipe so that would be next to impossible to happen. I also popped the valve cover off to check everything there and everything looks perfect. Tried to turn it by hand and it would not turn. Please help me diagnose this. :confused:
Take your plugs out and try to crank it.You might have to drop the pan and start looking around .Was it raining?
Check your timing markes and make sure the belt did not skip a few teeth
Yeah ouch is right my friend i feel the pain from here. But how? I don't see how you could of been driving it (obviously if the timing was that bad to break all them valves you would of known from the first start up) just fine then you pop a coupler with this result? It had to jump time or bad clearances. Hope you get her fixed up man good luck!
Think the rust will be a problem? Buying another head this week. This is just another example for all the newcomers when you want to turbo upgrade SUPPORTING MODS!!! I will be doing a build thread soon just a mild one though.
I think rust is the least of your concerns if you're planning to use this block again given the fact that the pistons hit the valves hard enough to break them. Cracked pistons, pinched ring grooves, and bent rods would be right up there.
Id most definitely have the block checked by a machinist before i dumped a penny on anything else. You may be in for a full build. That is brutal.
Well I'll also be fine if i need another block, my brother has one that he would lend me to use i would only need a head. But I'll still get this one checked.
She'll be back though, as all of you probably know or will know every time dsm breaks down it comes back even stronger!:thumb:
Im sitting at work and I said "damn" out loud. Thats just painful. Your into a full rebuild at this point or looking for a running engine.
Yeah just trying to stay positive hit me kinda hard. But I guess I'll start taking the bottom end out, and also look for our spare bottom end and take them to a machinist and see what they say. Mods you all can resolve this :cry:
