How can I remove the turbine housing on a 14b?
Ervin_S
Nov 2, 2005
Lincoln, Nebraska
I want to take of my turbo housing but I have no idea how to remove it :sosad:
Can anybody help me out? I've read the tech guide but they only have instructions on how to remove a turbonetics housing not a mitsubishi housing.
I'll answer anyway, since I played with my 14b for weeks before I actually installed it. The 14b center section has a circular ring around it with a bolt holding it together, similar to a T-bolt clamp. Simply loosen the bolt and the ring comes off. A small metal dowel pin fits into a hole on the exhaust housing, to keep everything in line. Don't lose it or break it.
The T25 on the other hand is bolted on, and if the bolts are seized, like they were on my dead T25, they're harder to get off. We just decided to torch them off, since the turbo was junk anyway. Dissecting things to see how they work (or how they failed to work) is fun!
