Can a 14b use EVO Turbine Housing?
OneFastEclipse said:
You'd have a larger turbine housing, thats all.
you'd be going from a 6cm^2 housing to a 7cm^2 housing. As long as its a Mitsu housing it works.
Advantages? up top in the RPMS it should be stronger. you lose some spoolup though.
Well I currently have my 14b exhaust housing ported by slowboy racing to 7cm. Are we talking the same amount of flow then or do they just gasket match it? My turbine housing has a huge crack in it so I need to replace it but I don't want something that might hurt performance. Thanks!
Not sure if they gasket match it or not. You'd have to ask them personally. Good luck!
