how big of fuel injectors?
550's will be almost maxed out on a big turbo with 18psi. I would suggest getting larger so that your ecu doesnt pull timing for high injector duty cycle. :thumb:
sqhopeful said:
depends on what turbo.....but you prob will need something a little larger than 550's
Depends totally on the turbo, if you want a t25, then 450s should be ok , but if you want a 18g or something, 650s?
it depents on your supporting mods.. i'm not very familiar with the 420 motor.. but a guess should be around 300 wheel horsepower... just make sure you have sometime of datalogging or tunable ECU so you can control the injectors..
