How bad is this Tune
Iyaoyas
35
Oct 25, 2011
Brawley, California
Here are 2 WoT pulls. I just ordered a SD bundle and Wideband for the car. I allready talked to Banishedmonk about tuning it once those are installed. I am just looking for some help on what i can do until i get it really tuned. BTW I was boosting about 15 psi (thats what my boost gauge said). It would spike up to 20 but then quikly fall back to 15.
Forgot this was without my water/meth.
does anyone have any ideas on what i can do until i can get it tuned? please help.
Your combined fuel trims go anywhere from 2 percent to 5 percent added so id increase deadtime a little bit. Your airflowperrev is at .21 which is low so id increase your maftcomp sliders up 0-100hz. You should also go to captured values and add LTFT Lo and monitor that.
Coolant temp reaches 219 which is borderline overheating in my eyes. 1 degree timing is pulled anything above 206. 2 degrees at 215. Intake temps are also kind of high. Are you running SMIC?
